Nook:
The 1MM larger valves by wonderful coincidence are a perfect match from rather common 3.0 mid-90s Nissan truck valves. I paid $3.10ex / $3.60in each for them at a Portland Nissan dealer.
I forget exactly what model motor they came from, but it's a place to start looking. You will need to use Honda Vtec keepers and spring tops as the tops of the stems are a tiny tiny bit undercut right at the top. Other than that they are a perfect fit. You will also need slightly larger seats. (which of course you would want for larger valves, no sense in the same inner diameter seats for the larger valves) Any machine shop worth a crap can get the seats by dimension and install them for you. I rebuilt a set of heads with this arrangement, and they worked perfectly.
N
