Having some trouble.
bamasho
alabama
i have a 1993 sho. ive been having some trouble with it. ive already hooked it up to a modis and found out theat my egr valve is broken. the trouble ive been having is that the car will just shut off when i am driving. any suggestion to what it could be. thanks.
deercrusher
never running!
PA
alot of people that think they have a prob with the egr valve end up finding it's actually the dpfe or the egr snorkel passages are clogged. Did you check these issues?
Huntervf
Bored now
Back in Michigan ... again.
Welcome to the forum :)
In the future, please post your maintenance questions in the proper maintenance sections; you'll get quicker, better quality responses that way.
I'm not really sure what a "modis" is, but a bad EGR valve generally won't cause the car to just quit. There could be a hundred different reasons why your SHO is quitting however, with the most common being a bad fuel pump or cranshaft position sensor.
Your first step should ALWAYS be to check your SHO's trouble codes. It's very simple and it doesn't take any special tools (just a paper clip). Here's a great link that shows exactly how to check your codes, and there's another link further down on that page that will tell you what the codes mean. Since you have a 93 SHO, you'll have 3-digit codes.
http://www.shophoenixproject.com/eec/eec.htm
Check the codes, then report back and tell us what you got :thumb:
sperold
Last to Know
Look for a water pump leak. It drips on the crank sensor and kills the motor. When it dries out, away you go again - till the next time.
crystizel
