not sure if this is normal or what, given i have never driven another sho so dont konw exactly waht to expect. but it is pretty hard to get it into gears. it never grinds or just refuses to go in. so i dont think anything is really broken. its just takes a good bit of effort to put it into gear. especially 1st like at a red light. unless im slowly rolling foward then it pops right in w/ no effort. but most of them time you really gotta jam it in there. but like i said, it never once grinded even the slightest bit. and 2nd gear gives me some hassle too. if im not really payin attention, inbetween 1st and 2nd in neutral i hit a hard spot thinking its in gear, but its not. so i let off the clutch then start to grind, so i reclutch and slam it into gear. but unless its my fault like that w/ the clutch it never grinds. also when in neutral, unlike everyother 5spd i have ever driven in, know how you can go sideways like into 3 spots? but usually they always spring back into the middle spot. well not my sho, you move it over to either side and doesnt make the slightest effort to go back into the middle. this normal? seems like you just need to muscle it around and everything works fine though. am i in order for a fluid change perhaps? or just deal w/ it?
another subject real quick, ill be replacing my rear endlinks after finding that my sway bar wasnt even conected because of snaped endlink. any tips on doing this? couldnt find anything searching for it, but havent really looked at mine yet. a buddy said i would have to remove the strut? is this true? any advice on doing this would be great, thanks!
