half throttle woes
lincster2
Las Vegas NV.
Violent start
Well a compression or bump start in first gear above 5~8 mph would be a real jolter. When I do a bump start I do it in 2nd gear at about 5~ 15 mph... letting the clutch out briefly ... when I sense that it had started quickly engaging the clutch again letting the engine rev easily.
At what speed did you bump start it? Was the engine fully warmed up?
The battery check light sounds like you really bump started it a too high of a speed for the 1st gear.
The vehicle speed sensor (mounted on top of MTX transmission under speedometer cable) is a pretty cheap part at about $15. I doubt that it's causing much of your problems though. Go ahead & replace it & report back to us. You can be our test guinea pig to see if it sovles the problem.:)
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
I was pulling into a parking lot so I was doing 1st gear speed. I usually use 3rd gear to bump it but I was already in 1st. I need find some spare time to replace the VSS & TPS.
eacyde
Pinkley Taurus
Well, for $hits & giggles I swapped out the TPS to see if it would help. No dice. Now to climb under the parts car to harvest the VSS.
