Similar codes
I'm having similar problems plus the engine just dies sometimes.
Key On Engine Off
Codes
211.... PIP ie. crank sensor
452.... VSS vehicle speed sensor
542.... basically tells me that at one point in time the engine stalled
Key On Engine Running
538....not enough RPM change during "goose test"
I've performed these tests 8 times over 2 days.... engine warmed up...using a OBD 1/2 tester from O'Reillys Auto Parts.
Now let's go through each of the codes.....
211 .... this code came up only once during the 8 tests. If the crank sensor is going bad that would explain the engine dying.
452 .... this code came up all 8 times. A bad vehicle speed sensor can cause a non operation of the cruise control & the "moving" idle rpms to drop below the correct 1,200 rpms. My car has both problems. Possibly bad connectors or wiring.
542 .... fuel related, or just reporting that the engine stalled. Many other codes would pin point a fuel problem. Replaced the fuel pump, engine still dies randomly.
538 .... the tester prompts when to raise the rpms, all 8 times it reported that not enough rpm change had occurred. Floored the accelerator, once 5 full seconds, other tests snap, 1~2 seconds etc.
My thoughts are that the faulty crank sensor is not giving information to the tester/car's computer.
In addtion to the engine stalling, when applying extra fuel to a smooth running engine it would stumble slightly then accelerate. Checked the fuel pressure.... it was running way too high... 70 PSI, about 35 PSI is normal when running. Change the fuel pressure regulator.. stumbles no more.
Many mechanics told me that the only way to positively test for the true cause of the engine dying is to test when it happens, engine dies then test it right then & there. It's like trying to charge your battery by running around hoping that LIGHTING strikes it.
Anyway I'll report back when I change out the crank sensor. Hope this post helps you.
