H brace worth it?
underdog1924
Haverhill, MA
I may be able to get an H brace for a good price. What exactly does it do? Is it worth the money or am I better of saving my money? Thanks
philw349
PhilW
Tucson, AZ
I think that stiffens the box betwen the rear lower control arms. I also believe its something that won't make any difference unless you've done most of the other suspension mods first (sfc's, struts, springs, etc.). It helps them all work together tighter. It should probably be one of the last things on your list unless you plan on seriously working on suspension in the future and can get a real good deal. Someone will correct me if I'm wrong :)
<small>[ March 09, 2002, 05:54 PM: Message edited by: philw349 ]</small>
NJshofear
Medford NJ
well i have coilovers and konis. im getting them off ebay cuz they are going for 50 bucks. I hope this will tighen up the rear a bit bucause the coilovers are much stiffer than stock.
[email protected]
Albany, OR - USA
If I recall correctly, if you're getting the rear tubular control arms, it should most DEFINATELY be installed at the same time, or else the stress on the box will tear it up.
