Good morning/afternoon/evening. (Circle one)
I just removed my old guage pod and I am in the middle of installing another one. I did a kind of crappy job with the install the first time, and I want to do better this time. The guages are volts, oil press and coolant temp.
I have 3 questions:
1) Fred Hurder mentioned (in a post a long time ago) that he had his stock temp guage as well as the aftermarket guage hooked up. How do you do that? Do you get a fitting and screw 2 sensors into it?
For the next two questions, please be specific. I am wire diagram-stupid.
2) The lights in the guages have 2 wires. Black and white. Where do each of them go? I would like to have them come on with the headlights, and I have read something about red and yellow wires behind the headlight switch. But do I hook both wires into the headlight wires, or does one go to a ground? (I think that's what the directons said)
3) For the voltmeter, where is a good place to hook that up? And again, the same question, is it positive to source, neg to ground? I'm not sure, but I think I may have it hooked to a fuse in the fusebox, and the negative to a piece of metal behind the radio somewhere. In a possibly related issue, my radio doesn't work. Is the fuse box not a good place to hook this up?
So just remember to be specific, as I am really not good with electronic stuff.
Hey, it'sMonday. Only 5 working days until another weekend. (Oh,...sorry
Thanks for your help!
Tony
I have 3 questions:
Tony
