grrrrr...
FoeSho
Marshall, WI
Well My Rod bearings finally went south into the oil pan friday night and a rod let loose. The shavings cycled through the engine and scored up the cylinders bad and the rod beat up the block pretty bad. Needless to say there is even my precious cams are "slightly" damaged. Anyone want some *slightly* used JE pistons? They only have slight GOUGES in the skirts :)
This was a $2000 mistake on my part.
Upon further investigation, it appears last time I had the intake and heads off, I must have dropped alot of gasket material down into the engien and this plugged the oil pump screen and caused starvation of oil. I never got an oil light at all, and I kick myself for not havign an oil pressure gauge in this car..
Anyways, I swapped the old trashed engine over this weekend with a stock 120,000 mile 3.0, and did a 60K on it and replaced all the seals. I miss my power , thats for sure!
So basically I am back to step one, again. Screw it. I am keepign the internals stock on this one, maybe exploring a supercharger down the road.
I am going to concentrate my efforts on the suspension and brake snow though, since I want to autocross this SHO.
AREA 91
PA SHO SHOP
Area 91
Ouch. We all make mistakes, some just more costly than others.:oogle:
FoeSho
Marshall, WI
Yeah, no matter how much you THINK you know, mistakes seem to balance a guy out a bit:)
At least I am driving it again..
LeddZepp8687
The Keg Rider
Naperville, IL
I dont get it....If you installed forged internals, You replaced the rod bearings at the same time right?? And if it hasent been long since changing rod bearings and they failed...Maybe it was an improper install?
*edit*
WOW, Im stupid.....I just read that the RTV caused oil starvation...
FoeSho
Marshall, WI
Its ok, yes the pistons were forged JE pieces..The entire block was machined and rebuilt, I assembled it to make sure it was together right, and it was. I have pulled the intake off several times to access the rear valve cover and even had the heads off to check some things , thats where the problem was. I didn;t cover the lower intake openings because "what could possibly fallin there" :)
well gasket material, and old RV apparently.
