Group Buy for Schwartz Engineered Performance Taurus SHO Intercooler Kit
skyshadow07
Oklahoma
I'm not sure if my crash bar will hold up as well as the stock but it's lighter haa.
Linemonkey
Has anyone been able to compare the Mishimoto with the GHIC?
Sent from my SM-N960U using Tapatalk
Further down the road, I am going to sell my GH IC and incorporate an A2W IC into my setup. Between your one off crash bar and the BMR crash bar it has made things less daunting.
aaron240
Cambridge, Ohio
www.schwartzep.com
Please check out the performance graphs in the middle of the website page to view the cooling performance this intercooler solution brings to the table when compared to stock.
stripSHO
Idiot Savant
Detroit
www.schwartzep.com
You don’t by chance have any pressure drop data do you? Or maybe logs that can show changes in wgdc at a given load? I’ve read from several members that the GH intercooler presents a substantially higher flow restriction than stock (in stark contrast to GH’s claim), which at anything above 15 psi boost target is basically a death sentence for stock turbos as far as I’m concerned.
aaron240
Cambridge, Ohio
Unfortunately I do not but mishimoto has test data on their website. What particular tests would you like to see ran. I would love to further validate this performance solution and bring more test data to light for this intercooler setup.
stripSHO
Idiot Savant
Detroit
It’s not anything they publish, or any other IC manufacturer it seems. It would be cool to know the pressure curve (Y delta pressure at X cfm airflow) of their intercooler but it’s no biggie really.
yaycandy
Aerospace Engineer
Hanover, PA
Oh they will give you every bit of detail if you call and ask. As Aaron and I both have
yaycandy
Aerospace Engineer
Hanover, PA
I've looked heavily into it and its do able. They make a2w intercoolers that will fit and then run a coolant pump and reservoir similar to where the water meth would be located on bottom corner of front. I was gunna run it to a water oil cooler and to a a2w intercooler but never did. My next plan is smaller intercooler mixed with multiport meth spray, already drill and tapped a spare intake manifold i had.
skyshadow07
Oklahoma
EVERY water to air intercooler I have ever had would heat soak on a road course. I think that's why they are only found on dragsters. Short runs then plenty of time in between to swap water or allow to cool.
yaycandy
Aerospace Engineer
Hanover, PA
Didn't think of that. I need to do more research of real world on the topic. So far on paper it works out but the on erf is where it matters
I have pretty much made my mind up and will be going A2W in the future. I will be adding at least a 10 gallon water tank in the spare tire compartment. That will give it more then enough water to keep things cool for the my plans. I will just use it like the newer blower cars and their heat exchangers.
Clearly we don't have same goals for our cars, but I will be more then happy to share all the data once I conduct the testing.
yaycandy
Aerospace Engineer
Hanover, PA
Gotta tap into that air conditioning like the Demon. Line that right into intercooler piping. Turn on your seat cooler for your hot Arizona ass(this came out wrong) and BAM more powa
Hahah, I think with such a large water median I wont have too. I am not worried about weight. So adding another 120 lbs in the correct spots might actually help me.
shootinirons
