Thanks
No I left everything on. Just spray it thick enough so it will peel off of the areas you dont want it on. It cuts its own edge as you peel it so the lines are perfect. I did tape and used paper to cover some areas to help with some overspray but you want it to overlap the chrome so you have a peeling point to get the edge to cut right.
Any prep before spraying? If I do this on some exterior parts how long until I can drive without worrying too much?
