will it sho?
Hey all,
Just ran the codes from the excellent info on http://prochilo.myserver.org:2080/abs_codes.html
Well, on that page it mentioned that the codes have a cascading effect usually from your first code. Mine were in this order:
22 (Ref. Voltage of IFL)
24 (RH Front Inlet Valve)
41 (LH Front Sensor)
44 (LH Rear Sensor)
43 (RH Rear Sensor)
61 (FLI Circuits)
62 (Travel Switch)
What exactly is the IFL? What is involved in fixing it? Are all the other codes effected from code 22?
Thanks for the help in advance.
Paul
44 (LH Rear Sensor)
43 (RH Rear Sensor)
61 (FLI Circuits)
62 (Travel Switch)
Paul
