got codes 565 & 157 what now?
SMD69
Reading
565:CANP solenoid circuit failure
157:MAF circuit below minimum voltage
What do i need to do to fix them?
I dont know what a CANP stands for and where it is to fix or replace.
What do i need to fix on the MAF or do I need to replace it?
Thanks
projectSHO89
SHOless In St L
CANP = (CAN)ister (P)urge valve. Follow that single vacuum line from the front on the intake manifold near the throttle body downwards behind the driver's side headlight assembly. The hose plugs into a T-shaped fitting on the CANP valve. The hose on the other end of the fitting goes to the charcoal canister. Make sure the electrical plug is plugged in on the other end of the valve. If this electrical circuit is open circuited, i.e., unplegged, you will get a 565 code.
The 157 code is often, but not always, caused by a faulty MAF sensor. More troubleshooting is suggested before spending money on parts.
Troublehooting by looking only at codes is insufficient. It is suggested that you also give relevent symptoms about what you are trying to fix. It is also helpful if you keep your efforts in a single thread.
Steve
