got a problem ya ll
rangerj
Brunswick, Ohio
Brandon,
Have you tried a fuel pressure test? Maybe she isn't getting fuel! If the fuel pressure is at least 30 psi, running, that is not the problem.
Are your secondaries opening?
Do some basic testing.
1. Is it getting fuel? (fuel pressure tests)
2. Is it getting spark? Set a plug wire within a 1/4 inch of the engine and look for a strong bright spark.
if these are OK, then get the engine fully warmed up and check the codes in the KOEO, and KOER modes again. rangerj
SHO--ripper
928 Euro
winsted,CT
My SHO did the same thing at 174K. At idle the revs would drop. When i floored it nothing would happen. I replaced the fuel pump/filter and wallah! my SHO had power! thumbs_u That sounds like your problem to me. Also, if you're kind to people it will help you in the long run and make life better.I have learned that being a smart @ss doesn't get you anywhere.
SW SHO
Boss Man
Santa Fe, NM
Brandon-
Did you do any further tests. We'd like to know you are closer to solving your fuel problem?
Let us know!
brandon
Ohio
no have not had the time i think it is the problem but not checked yet
markmoomnu
