Hubes:
hey chris i was bored yesterday was surfing shotimes. they have a great how to article with pictures also showing you how to change the fuel pump. here it is as quoted from shotimes
Fuel Pump Replacement
When it comes time for fuel pump replacement, consider putting in an aftermarket higher capacity pump. It'll cost less than Ford's pump, have to work less (since it's rated higher), and provide more possibilities for future modifications. Here is a link to a good page about Walbro fuel pumps (both information and ordering) - several SHOtimers have ordered fuel pumps from this source without problems. As noted in the footnotes, the Gen1 and Gen2 SHOs can use the pump listed for the '85-'97 Mustang.
Thanks to John Gentry for this procedure :
As most of you know the stock fuel pumps that Ford put in the early Taurus line are rather weak and prone to failure. When I replaced mine at 75,000 miles I could tell a difference after I added the 155 lph (liter per hour) pump. That is only because my old pump was about to go out. Don't expect a new pump to add rocket thrust to your stock SHO. However, the higher volume pumps do become a factor as you modify your SHO such as by adding cams or a supercharger.
You will notice that I didn't take photos of every step in the procedure. That is because when I took the pictures a year ago I did not have any intention of writing up a fuel pump replacement procedure. Only use this procedure as a supplement to a shop manual such as a Helm or Chilton's.
I ordered my fuel pump kit from Doug Lewis of F.P.S. It came with a new 155 lph pump, fuel pump mounting gasket, clamps, hose, mesh sock and instructions. The day I did the procedure it was a windy day and I lost my instructions after I removed the first three bolts at the filler neck. So if you order the pump from F.P.S. put your instructions in a secure place and use your shop manual along with this procedure.
I dropped the tank and changed the pump by myself without any help. I strongly suggest that you get a friend to help you especially if you need to drop the tank like I did. It took me about 3.5 to 4 hours to change out the pump and reinstall the tank. It would have gone a lot faster (about 2 hours) if I didn't have to drop the tank and had help. Have fun!
These are the tools that I used:
10 MM 3/8" socket
13 MM 1/2" socket for tank strap bolts
5/16" 3/8" socket for fill hose connections (if you need to drop the tank)
2 1/2 foot hollow metal pipe to fit over ratchet handle to use as a cheater bar. (The handle from a large floor jack will work)
Long flat head screwdriver
Masking tape to mark fuel lines
Large floor jack
Wheel chocks for front tires
Heavy duty jack stands
Fuel pressure gauge with relief valve
Gasoline siphon with 5 gallon fuel can (only if you have too much gas in the tank)
Dremel tool with a small cutting wheel
