goin back to the track... need advice...
DavidT
TN
Last time I went, I had the entire saxacone still in. Ran a 10.3 in the 1/8. 60 ft was 2.4.
Now I have totally removed the sax, leaving a hole at the airbox inlet. It SOUNDS much meaner :D
Should I run it like this
OR
Install a 3 inch diameter flex. drier hose (chrome in color)?
I am only going back because the temps are 20 degrees cooler now.
I really want to see some 9's...
I am wondering though, would the cooler temps even help me if the airbox is pulling in air from the engine bay...
Glue Maker
The V8 Paradox
Sugar Land, TX
I didn't notice much of a difference with the K&N. But my thinking is "Well...If they saw so.."
It sure sounds meaner :p So I don't know if it would be worth buying the dryer hose...
If you're running on street tires, don't try to launch it! It just makes things worse! rant
I bet you'll get 10 evens or 10.1s with cold weather. There is a very noticeable difference in time with temp/humidity changes in SHOs.
WELD YOU CAMS! Bad bad bad when they throw! My car did it with out warning!
<small>[ October 26, 2003, 01:26 AM: Message edited by: Glue Maker ]</small>
stephen newberg
Ladysmith, BC, Canada
"I am wondering though, would the cooler temps even help me if the airbox is pulling in air from the engine bay..."
They will until the motor gets warm. wink
I would suggest installing that tubing to the wheel well to make sure the air going into the air box remains cool.
pax, smn
Ian Macoomb
Ottawa, Ontario, Canada
DavidT:
It should. I run the same intake setup and sub 50 degree (F) weather has gotten me sub 10 second 1/8th mile passes.
