EL SHO
Taco Manager
I'm having a weird intermitent issue in which I am getting low voltage at dash and accesories like stereo, windows and cigarette lighter.
I measured this through an analog gauge I custom installed and also by checking with a digital multmeter.
At dash sometimes I get between 10 and 11.5 volts, this is with the car running.
Whenever I notice that the volts drop, the temperature gauge in the dash moves to the HOT position, but I know the car is Not overheating. When the volts return to normal, the temp gauge returns to normal range.
I do not get the low voltage warning light.
At the same time I check the voltage at battery terminals (car still running) and I get 14.2v reading even with lights and AC on.
Where is the car loosing those volts between what the alternator gives and the dash is receiving?
I have checked the battery grounds and they look good. In fact long ago I installed 3 more ground cables plus the stock one.
Positive cable also looks good.
Any ideas?
Any ideas?
