getting A/C belt off
SHOslamwagon
Toronto
ok so it's a 1992 with 200000 ish km on it, im trying to get the A/C / Alternator belt off to get the A/C compressor off. I figured it was just a case of loosening the allen/hex nut that was above the (tensioning?) pulley. (the one kind of above the crank) so i began loosening the nut and just kept loosening and nothing was happening. i was fully expecting the pulley to move up along the apparent track but to no avail. So now what?
SHObill
'The Collector'
Rochester MI-48307Detroit
You have to loosen the nut holding the idler pully to the brkt before the pully will move! It is a 5mm allen & that should not have been able to turn so you could have stripped/broken somthing. Usually you strip out the allen first if do not loosen the nut on the pully first or break the 'C'clip!
shovermont
unleasing my 91
Vermont
so you HAVE to loosen the pulley nut for it to move up and down? i am having the same problem and made a post but nobody responded. is there a correct tension to crank it back down to when you put it back on. thanks a lot
SHObill
'The Collector'
YES, you HAVE to loosen the pulley nut for it to move up and down! The nut on the stud locks the pully assy in place to hold belt tension. This stud has another nut on it inside the brkt that the adjustment screw passes through. If after loosening the pully nut & the screw will not move the pully assy the screw is rusty or stripped. You must then remove comp assy brkt off motor & repair or replace. MTX frt & rear assys are unique. Also be carefull with the washer behind the nut as it can only work 1 way! If you put it on backwards it will bind the pressed in bearing!
shovermont
unleasing my 91
Vermont
thanks a lot for that help. that totally answers my question. i was so stumped trying to figure that out. the only question i have left now is what should i torque the pulley down to? you guys save me a lot of hassle:hail: thanks
