JohnW63
I just found this forum and thought I'd post a few simple questions.
I have a 1995 SHO with ATX. We have about 106K miles on it and I have a small laundry list of things that need attending to.
The Check Engine light had been lighting up more and more often, so I read part of the codes with a jumper wire and watching the Check Engine light flash. Since I could not tell what to do after reading the code. ( a 189 ). I took it to a local shop and they read the codes for me. They said that both sides of the motor were too lean, the MAF sensor had an error, and the engine temp was not comming up to spec. They found the fuel filter was VERY plugged and I had them replace it. They reccommended replacing the thermostat. Replacing or cleaning the MAF sensor, and having the fuel injectors cleaned. I swapped the MAF out and I have purchased a thermostat but have not yet installed it. The engine light has not come on since. It seems to run smoother now too. No pinging on hills.
Ok, here are the questions:
Do I need to have the injectors cleaned or is the stuff in the can any good ?
I have not yet changed the factory timing belt. Is it nessisary at this mileage ?
Who makes decent brake pads for these cars ? All I can seem to find, at local parts stores, is inexpensive organic and ceramic. ( Stock 1995 rotors )
I have found sites that mention that a gasket is NOT needed for the thermostat, is that true ?
Who makes a good serpentine drive belt ? The local parts store has Goodyear, for about $50.
That's enough for now.
John
<small>[ March 18, 2002, 01:14 PM: Message edited by: JohnW63 ]</small>
John
