Gen. 2 foglamp and interior door trim piece...
DavidT
TN
Anyone have the foglight lens assembly. .. the piece that the bulb fastens to is cracked on my drivers side. Also I have black interior. The top part of the front driver side door , which has the piece the door lock stem goes through is totally butchered. .. the rest of the door is mint. Can I just replace that one piece?
NoSlo
SHO Owner
Portland, OR
The door panel is all one huge plastic piece. The vinyl on the top of the door is a separate piece but it is bonded/melted together at the factory. If you break off all the tabs that holds on the top puffy vinyl cover, it would take a lot of epoxy to stick it back.
1284411725 1995 taurus door panel removal p9130156
I have a wrecking yard fog light, but it's typical 20+ years old needing the headlight refinishing sticky done to it.
