i need the one that goes on the crank and ac compressor. I heard summit has these for the sho, no one else so far has them. also if i have the 3 piece sho shop underdrive pullies what size do i need? anyone know any part numbers ?
Gates part number K060445 is the the Alenator/Compressor belt on a MTX SHO
This is incorrect!
That p/n is for a 44.5" belt. It should be K060450, which is 45". Many parts stores list the incorrect 44.5" belt when you order using your car info, so you have to order by part number when purchasing this belt.
i said i have underdrive pullies, i'll just order a 6 rib 43 inch belt whatever i can find first since someone has something good and bad about all brands, thanks guys
Seems to be the best place to add this. Confirming that the stock AC/alternator pulley on a 94-95 MTX is K060455 or K060450, six rib.
What is harder to find are the belt sizes used with the late SHOshop three piece underdrive pulley set for the 94-95 3.0 MTX, this kit had larger power steering, water pump and alternator pullies but did NOT have an alternate crank pulley. Sizes there are :
Power Steering/Water Pump Goodyear Gatorback 4040600 / 4PK1270
Alternator/AC Goodyear Gatorback 4060465 / 6PK1180
The power steeering/water pump belt is a 4 rib. Gatorback is the only belt I found would not squeal under autocross use.
One more note - running the stock belt with an underdrive alternator pulley puts the idler too close to the battery, have seen this cause the pulley to chew into the battery during autocrosses, etc.
