Twisted6
Has anyone considered this technology and retro-fitting it to the SHO? We already have the benefit of an OHC 4-valve head, which relocates the spark plug to the center of the combustion chamber. DI technology has been around for about 80 years, but just recently has technology gotten to the level to take full advantage of it. In a DI setup, the fuel injector is relocated right into the cylinder bore, it requires a specialized injector that is much higher pressure (2,200 PSI) and can also withstand the temperatures and pressures within the cylinder. To achieve this pressure they also require a specialized high pressure fuel pump and a fuel rail with usually, at least, 1/8" thick wall tubing to withstand that kind of pressure.
Outside of the fuel system, it requires specialized pistons, moreso a U-shaped relief where the fuel injector sprays into. DI systems typically operate in three different modes:
Ultra-lean burn: At idle or light-running conditions, fuel is not injected during the intake stroke, but rather towards the end of the compression stroke. This applies a very small air-fuel mixture right at the spark plug and since the remainder of the cylinder is filled with nothing but air, this keeps the fuel and flame away from the cylinder walls, reducing cylinder temps (Which would normally increase in a port injected system trying to run this lean).
Stoichiometric: For moderate-running conditions, fuel is injected during the intake stroke at 14.7:1 AFR.
Full power: For heavy acceleration, fuel is still injected during the intake stroke, but slightly richer.
By removing the injectors from the intake manifold, you allow air to flow uninterrupted through the manifold. Some OE manufacturers add bumps and trips to the top and bottom of the intake ports to create a tumble effect for increased part-throttle response.
Another major benefit of DI is the ability to run much higher compression ratios while retaining the use of pump gas and the ability to run boost on high compression.
Would TwEECer be able supply this kind of control through the EEC-IV or would a standalone EMS be needed?
