Gaskets
lunchbox0029
Fort Worth
Do you nee to change the intake gasket to do the valve cover gaskets or can I just take the tanks off the intake 95 SHO 3.2
K-Dawg
Treasure Coast, FL
You'll need to pull the intake off the heads to pull the valve covers. You may or may not need to replace the metal gaskets between the heads and intake.
Ishodu
You do need to remove the intake thats for sure, the metal intake gaskets are reuse able as long as none of the black finish is damaged.
