v3r71g0
Where is the fuel pump located on a 92' SHO?
Is it under the backseat or in the Trunk?
Where is the fuel pump located on a 92' SHOE?
Unless you live in the salt belt. In removal, you run the risk of breaking strap bolts, tank straps that are rusted to the tank, and the resultant holes that are torn into the tank when you attempt to remove them, and other fun maladies like that....You'll spend more time cutting than removing and less of a chance of major catastrophe.
It's in the fwd right hand side of the fuel tank, underneath the rear passenger seat area.
Some guys have cut access holes thru the body under the rear seat. You can find instructions @ www.shotimes.com however I personally don't recommend doing it this way. fuel pumps don't get changed that often, its not that difficult to drop the tank and replace it the correct way. Doing it correctly will also allow you to remove any sediment (especially weld splatter that FORD may have knowingly left behind), inspect and clean the tank. You'll spend more time cutting than removing and less of a chance of major catastrophe.
