Fuel Pump, Beeping and Rad Fan
mrgrim333
Colorado - Northern
Ok, so here's my issue.
It was a slurry of junk until minutes ago.
Now, my fuel pump isn't turning on.
CEL code 556.
Works when hotwired strait to the battery.
2nd issue.
Radiator fan seized. Melted the wires connected to it.
Replaced with a new fan and plug.
Doesn't work.
Both issues are CCRM I assume?
zblackbeast
SHOtarded
Omaha, NE
Junk yard.. or make a post in the WTB area..
Make sure you get the correct ccrm to.. 89-93ish mtx used a D, 94/95 mtx used an M and I forget what the atx uses
mrgrim333
Colorado - Northern
So when I pull CEL codes, I get 543 and 524.
But here's an interesting bit, I got a new ccrm but am afraid to put it in. Here's why.
I have a direct line from fuel pump to fuse to positive battery.
Works fine... UNTIL, I try and turn on the heater (usually how I get my radiator fan to spin), it blows the fuse. Both 10 and 15 amp.
What I'm worried about is, I just replace the fan because the last one sized and melted the 2 inches of wire leading to it. What I'm worried about is it melted the wire farther up the harness
