Fuel problem
1QuickCoupe
Gillette, WY
I pulled codes on my car (95 MTX) awhile ago, and I got a code for a bad ground on the fuel pump. Since it didn't seem to be a problem, I ignored it. Well now, it will not start, fuel pump will not even turn on. Where should I start to look for the bad ground problem. Isn't the ground ran through the wiring harness? Thanks, Art
ohfosho
ontario SHOwner
ontario, canada
check the simple things first, like the inertia switch in the trunk, as it shuts power off the the pump. other than that you may be looking to change your fuel pump soon.
1QuickCoupe
Gillette, WY
Yea, I was thinking that it is about time to change the pump. Hopefully it will last long enough to drain the full tank! Thanks guys
