fuel pressure?
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
39 psi at the fuel rail with the car off and the fuel pump running (jumpered at the EEC port).
If you measure the pressure when the car is running, you will need to compensate for vaccum as it will adjust the fuel pressure regulator.
Mike
justin mccluske
washington
Thanks! i figured it was around there but when i used the search function all i could find was 30psi and i thought that was alittle low.
