How do I get this out? It seems like I'm going to have to remove the frontmost intake runners to make room to pull this? If so, does this set of runners have a bolt on the bottom of the tank? Is it possible to pull just one set of runners or do I have to remove the entire manifold? Do I have to replace the gasket if I remove the manifold?
Seems like this leaking fuel pressure damper is quickly turning into an upper 60k!
Thanks for all input. -Joe
