I am planning on installing a volt meter to keep tabs on my battery, and I will be using a pillar gauge pod. I am also considering installing an air/fuel ratio gauge and a fuel pressure gauge, all from Auto Meter.
Anybody have any experience with these last two gauges?
http://www.autometer.com/cat_gaugelist.aspx?sid=12&opid=1&szid=2
Their page says that the air/fuel gauge will work with some narrow band oxygen sensors; if not then you will need a wide band O2 sensor. Since I am also considering a Tweecer for the future, I wonder if I will be able to use one O2 wide band sensor for both.
How hard is it to tap the fuel pressure sensor into the SHO fuel rail?
Jose
Jose
