Fuel injectors that fit stock rails.
93rev2sev
Hockeytown
According to Toolman, there are upgrade injectors that fit stock rails...
[Keep in mind that some injectors will require you to modify your fuel rails to accept them. Others are available that will fit a stock rail with no modification....
So what's available in the 39-42Lb range to fit stock rails?
Sho Amo
SmkTyresntDrugs
Olney, Md
which is kinda a play on tim's words. although he said they fit with no modification im pretty sure josh at shonut modifies them for you.
SHO NUT
Ingleside
Yep ... that's how we sell them as 'no fuel rail mods required'. :)
ACCEL 48 lb/hr injectors, set of 6, modified to fit the V6, for STOCK rails, does NOT require rail mods, direct replacement for stock injectors, includes rail o-rings, head seals not included (LIMITED SETS IN STOCK) SNP-A48SR 380.00
93rev2sev
Hockeytown
Hey Josh!...
I was just reading that...lol
Anyway...what about these head seals...are they just standard injector seals? How much are the ones you carry? They aren't listed.
SHO NUT
Ingleside
Hey Josh!...
They are just standard SHO head seals, as we make the snout (head) end of the injector the same OD as the stock injector. You can re-use the old ones, or get new ones practically anywhere that services injectors, or sells injectors seals.
http://www.shoforum.com/showthread.php?p=720628&postcount=3
http://www.shoforum.com/showthread.php?p=73079&postcount=6
We used to sell the Ford ones, but they went obsolete.
bmytych
