Fuel Compression results
RI-SHO
B to the BANNED
Pawt., RI
SHOTIME:
Edien, You car has no backpressure. what do you expect.
CIA and straight through exhaust with no resonator. the more air it moves, the more gas it uses, and often doesnt burn.
I have hi-flow cats with PP y-pipe thats what more back pressure do I need.
twr
whoohoo
half-way there, I think.
RI-SHO,
I bought mine at Napa for no more thann $40. Do you have access to another SHO so you can borrow one?? Don't forget anytime you replace a sensor, to reset the computer.
RI-SHO
B to the BANNED
Pawt., RI
Oh I thought you were talking about the FPR, is TPS something easy to remove/replace?
Since i'll be disconnecting the negative what do you think would be a good replacement for negative terminal. Because the one I have now is stripped and wont get any tighter, it disconnects from the battery on certain bumps on the road.
