stockblue95mtx
stockblue95mtx
I'm been reading posts on front wheel bearing replacement but haven't found one that tells how to do the job on a shop press. Looks like the center hub (with studs) needs to come out of the center (cones) first and then the bearing removed from the knuckle after the snap ring has been removed. Is this correct & if so how does one support the knuckle?
Thanks for your help in advance,
stockblue95mtx
stockblue95mtx
