jmpSHO
Anyone have any good ideas on removing a front subframe bolt that just keeps on spinning. I tried prying down on the subframe while using my impact gun but it just spins.
I know there is an access hole but it's awfull small to get in there to see what's going on. Has anyone ever cut there own access whole? I was thinking of cutting my own hole and welding up a piece when I am done. If I do get it out do the same nut/tabs that you use on the rear subframe work on the front as well?
