FRONT MOTORMOUNT QUESTION...
SHO SPD
SHO member #480
Naples, Florida
Is the rubber part of the front motor mount attatched to the motormount as a whole, or can it move around while still attatched to the thing that connects to the motor? Mine I can move it around like the rubber part is not connected at the bottom, or on the sides, its only attatched to the bolting mount thing. It also has a pin above the rubberpart in the center of the mount that appears to be holding the rubber in so it cant come up out of the little hole.
1989 Titanium pearl
CAI- Thanks to justinrsho
K&N cone filter
G-tech times
0-60....6.61 sec.
1/[email protected] MPH
From top to bottom
Justins 98 (justinrSHO)
Mikes 93 ATX (SHOtime93)
My 89 (SHO SPD)
"Dont tell me, SHO me!"
jthomas68
Area 51
You shouldn`t be able to move it from it`s sides.It does flex,but not pull from any edges.The pin is there to limit it`s flexing.The reinforced ones have a piece of angle iron under the pin for further dampen it.Kinda like this O
V
Jeremy Thomas
Modified 91+
Pic Of The Week:
Bonita SHO
Kent City, MI USA
THIS IS SUPPOSE TO BE SHO SPD, he accedntaly for got to change the user name.
we use the same computer!
Thanks, do you think that it would be to the effect that it is broken with it moving all around like that? I was planning on putting it in today, maybe just welding it all up will fix it.
[This message has been edited by Bonita SHO (edited 11-24-2001).]
ribeye2065
