Front axles replaced this weekend. Not a bad job.
F-22 Raptor SHO
7015 feet above Sea Level
Well, after reading as much in the archives as I could get my hands on and getting input from emerald93 and rangerj (yea ranger, its been that long before I did the job), I finally replaced my axle shafts.
When I bought the car last September, I saw that both cv boots were wide open (read, cut completely in half). I used that as a negotiation point and got the car cheap. The axles were "wet" with a bit of grease, but still open to the elements. (In AZ, that means alot of cinders and dirt). No clicking or clunking was present, but it was something on my mind, so I bought the complete axle assembly and was looking for someone to help me do the work as I had never done this before.
Forum posts scared me to death when they said CV's could fail catastrophically at any moment if the boot was "dry" and you were lucky if you could get 1000 miles on a dry cv. Hmm, I doubt that, but I should get it done right? Well, after 11,000 miles of driving on these boots, I finally replaced them. Motivating factor? Well, the inner boots were starting to leak and the grease was getting on my exhaust.
Not a bad job. Scott's references to his procedure were no longer in the archives, but his autozone procedure recomendation made it seem simple. Here are some tips you might find useful if you ever do this yourself as it is fairly simple albeit time consuming
1: Must have tools include a 2 x 2, 2 x 4 or a long pry bar, and a seal puller.
2: Before you start, make sure you have a new output shaft seal for the tranny, 2 new 18 mm bolts and steel lock nuts as you should not reused either of these parts. Believe it or not a new seal is 2.99 at autozone, buy 2 of them as you might bend one during installation.
3: when puting the new MTX seal in, pause for a moment to look at your archilles heel of your SHO which is the diff pin...you can see it when you take out the drivers axle. touch it, pray over it, say nice things to it, whatever, just remember its location as you want it to remain there as long as you own the car.
4: As many always ask, what do I disconnet to get that spindle out of the way: after taking off your tire, there are only 2 nuts to remove to get the axle out. autozones procedure shows you, but note: you do not have to take the ball joint apart nor the front sway bar, just the axle nut in the center of the wheel, and the 18 mm bolt next to the abs sensor. thats it....nothing more....piece of cake....(thanks Paul aka emerald 93)
5: go to home depot and for 1.50 you can get a piece of pvc to tap the new seal in perfectly.
It took me probably 4 hours to do the job as I drove to the parts store a couple times and was pretty intimidated by the project. I tend to take my time when I am intimidated.
Emerald93MTX
ME student at Clemson University, SC
Dude, I'm so glad it worked out for you. This is what I love most about this forum is the sharing of information that truly lets people be there own mechanic and save lots of money. I was driving around the other day and saw a sign in front of a shop that said they were CV Joint Specialists and would do a CV replacement for 99 dollars (for most vehicles) and to think that it didn't cost me a thing in labor to do it myself. The fact is that it would have probably cost a whole lot more at that shop being that it's a SHO, but still, a hundred bucks can pay for my new oil pan gaskets, rear main seal, new TOB, and rod bearings.
Again, congradulations
Paul
DavidT
TN
congratulations!
The shoforum is unparalleled :thumb:
My ex. white 90 needed them when I first bought it. I was too unlearned, still am, to do it myself.
I found a local garage that charged $30 labor :eek: And I had $200 in a new set of axels from Autozone... $230 total.
At any rate, nothing like doing it yourself though. Nice job!
blk\blk90
TX
Mine are open too. I'm scared of pulling things out of the transaxle though. :cry: Actually, I'm scared to do anything besides change the oil and various coolant hoses that rupture. :jpshakeh:
Emerald93MTX
This is an easy fix, just a little expensive if you want new parts, but not too bad for SHO parts. Get F-22 Raptor to send you the messages I sent him. You'll be done in no time and telling others how to do it. Good luck.
Paul
Off Road SHO
Moderator
Way to go Mike, now come down here and help me fix the Othe Woman. It's only going to be 106 today (going through a cold spell). :D
Tom
F-22 Raptor SHO
The axles looked as intimidating as the 60k, but having done it, now I am no longer wet behind the ears. Well, sorta.
Paul: between you and Jason (yamahasho) I got it in my head that I could do this job and there was no stopping me. Heck Jason is like a young buck and he has done 10 times the amount of work I have done to my car. No way I let that happen.
Tom: 106! what the heck man, you do have ac in that place right?
Shoaz
Studly dood
Scottsdale, AZ
I've looked all over the back patio of Tom's shop for an ac switch. I'm sure it's there somewhere but I can't find it.
The solar heater works pretty well, though...
bmytych
