FreakSHO's Wicked Two-piece Crank Mod!
Tecchie
Marysville, Washington
Didn't yeild any extremelly useful stuff, as there was no mention of needing a harmonic balancer/dampener. So say if you got the internals all zero balanced and flywheel, pulley, etc, would that be good?
yamahaSHO
E85 whore
Arkansas
LOL... You can expand upon your search. The link is merely to prove a point.
FWIW, the SHO motor is an internally balanced motor. Balance the internals, then balance the dampner, flywheel, clutch, etc.
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Since I have read that a billet crank is better than knife-edged or what-not, is it even possible to get a billet crank for our shos? (mine is 3.2ATX) and if so, how much dough are we talking here.. cause I know billet parts aren't cheap..
One other question is when I am looking up parts for the engine internals e.g. the rotating assembly I see (like for my '90 Bronco XLT 5.8L 351W) that they have zero balanced internals (crank, rods, pistons, etc..) what does that mean? and is a harmonic balancer still required for zero balanced for high rpm?
Every engine, regardless of 'balance', creates harmonics in the crankshaft while running. Any engine run without a harmonic damper is at a very high risk of creating a multiple-part crankshaft. F/I cars are even more likely to have problems, due to the larger combustion forces acting on the crankshaft.
gmail
Well-Known Member
sunbury pa
i dont know where people get the idea knife edge crank is stronger or some crap.
do some searching and you will find your awnser.
there is a lot of stock motors also running around without crank dampeners so...
but i agree every engine makes harmonics, f/i i feel it is a needed part. but n/a
**** i run my 3.2 mtx with all under drive pulleys to red line all the time, that dampener is wasted power :)
also about the billet crank question.
there was a recent 3.6 stroker crank that was billet for 2k there some time ago JEM i believe has the 3.6 in his car and i would imagine its a monster vs stock 3.2
Tecchie
So, if an engine is internally balanced (e.g. Zero Balanced) you just take in the rods, crank, dampener, flywheel (talking of an ATX) to a machine shop and have it all balanced together and have the machinist mark where everything needs to fit back together in order to be perfect (or close to) ?
I am wanting to know for my other project as it has a 351W, and would help me with my sho also for the mods I want to do to it.
Thanks everyone for their time and advice, you have all been a great help.
I also have a question, is there anyone here in NW Washington Area that wants to make a couple hundred bucks to help me change a rear main seal in my Bronco? :p:swing: Biggest problem is I don't have a torque wrench, or a trans jack to move the beast, once that's out, the rest is easy.
oneqwicksho
cleveland, ohio
does any one know about a aftermarket crank for these cars that are like twice stronger than stock?.
someone said Doug can get them but i never checked into it. if so let me know. and what the cost is
yamahaSHO
E85 whore
Arkansas
Unless you're wanting to run 1,200hp/800tq, your money is better spent elsewhere.
