Is there a way to steal this instead of becoming one of your clients?![]()
You'd have to find someone that xeroxes our stuff
You'd have to find someone that xeroxes our stuff![]()
And remember, I'm not only the hair club president, but I'm also a client.:laugh_ti:
I assume that I should also be running "open loop" in my green car?
The resistor trick barely works in the 255 and won't work in the 255 HP. I didn't try a 190 though. I once wrote a long thread about that, but I think it's gone now. The conclusion was that you need our FPR with a 255 or 255 HP pump.
The 91 harness should have a jumper where the resistor is in the early cars. Try just plugging an 89-90 resistor into the harness instead of the jumper and see if that works for you. Remember that the high/low voltage switch in the EEC is based on TPS and TPS alone. Once you are past a certain throttle position, you are at full voltage, period. That may or may not work with how you drive. It's better to trigger based on vacuum level.
where would one find this jumper?
i think you need to get kicked off your high horse. quit bein trigger happy and have some cooth. i didnt mean to disrespect him in any way and agreed to follow his advice. you cant just go around editing everyone's posts for no reason. now someone will search this thread and not see why josh's kit is better than building your own. go be a dick somewhere else.Is there a way to steal this instead of becoming one of your clients?
LMAO! :laugh_ti: :laugh_ti: :laugh_ti:i think you need to get kicked off your high horse. quit bein trigger happy and have some cooth. i didnt mean to disrespect him in any way and agreed to follow his advice. you cant just go around editing everyone's posts for no reason. now someone will search this thread and not see why josh's kit is better than building your own. go be a dick somewhere else.
I realize that at 19 you know everything and everyone
It should be near where the 89-90 resistor is mounted on the firewall, as I don't think the harness changed much from 90 to 91.
K, found the plug but its missing a wire... it is supposed to have a white/pink and a black/yellow wire going to it but it has just the white/pink. how should i hook this up? and we are talking about the white ceramic deal with 2 wires going into the round plug resistor right?
-M
-P.S and for the life of me i cant find the damn wires on NY wiring diagrams...
