For turbo'd sho owners only :)
turbosho
Dallas
depends entirely on the rest of your setup,do you already have a fuel pump and programable computer? Buying a rising rate 1:1 pressure regulator is an easy way to allow you to tune for the street.
Sho Amo
SmkTyresntDrugs
Olney, Md
To answer your question yes. Even if you get the shonut fpr, you will still need a vacuum/boost source for the fpr.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
What you guys do for the stock fuel regulator vac hose? Leave it in place?
As has been mentioned, it depends on if you are using the stock regulator, which I can only assume you are, since you asked the question. So let me first encourage you to ditch the stock regulator and install a proper unit that will not give you the possible issues present when using a stock regulator and larger fuel pump.
On my setup, I am now using the stock regulator hose port as a boost reference.
Phoenix
SHOHOLIC
QC , Canada
I was thinking about making it like Sho amo , 5psi max , no tuner. I got a wideband to monitor it.
Thats for a start. Im sure im gonna make it to the next level later on.
yamahaSHO
E85 whore
Arkansas
Us Supercharged guys have to deal with fuel too.
Work the fuel properly, then boost.
Sho Amo
SmkTyresntDrugs
Olney, Md
When I first started out I had the stock fpr, 155 fuel pump, and the timing was set back 5 deg with the afrs in the 11s with 5 psi. My injector duty cycle was at 98%.
Phoenix
SHOHOLIC
QC , Canada
How can you set the timing 5 deg off when you had no tuners , at least thats what I understood back then...
Sho Amo
SmkTyresntDrugs
Olney, Md
I would never have run any boost without finding out where my injectors were. I definitely wasnt going to trust anyone on this forum to just tell me it was OK. So I datalogged at 3 psi where it was around 80% and 5 psi was at 98%. So thats where I stopped.
98dc
Sho Amo
SmkTyresntDrugs
Olney, Md
I think Phoenix is thinking about 91pdxmocha. IIRC he ran 5psi with no tuner and the octane adj switch removed.
I also think he blew a motor, cant remember.
91PDXmocha
Portland , Oregon
I blew the motor for sure but it didn't have anything to do with boost at the time. The turbo was completely off the car for state emissions long before it started ticking. It wouldnt even of blown if I hadent been a lazy ass and to drive it 20 miles home. It ran great while on the boost.
Then I burnt up a piston in the motor I swapped into the car after accidentally spiking 10+ psi with stock injectors still in. Swapped a piston in car and have the car driving again but it smokes at high rpm. Have most of a non-forged new shortblock built in my garage waiting to get finished.
