Fog lights not working
Kferg88
1991 SHO
Utah
Can anyone tell me where the fog light relay is located on a 91 SHO.
Irish Pride
Irish Inside
MusicCityUSA
Change the fuse. Its located under the dash but not in the fuse block. Its a seperate fuse on its own. You will have to remove the panel under the column to find it.
Also, please dont post the same thing in multiple areas of the forum. One thread is enough.
Irish Pride
Irish Inside
MusicCityUSA
so, does the dash light still light up if fuse is blown? my dash switch lights up, foggies dont.
Yes, the switch is wired in with the headlights so it will still light up, but the fuse is in line after the switch.
poffffd
