fog light replacement
SHONJ622
New Jersey
does anyone know if the bulb that needs replacement , the fog lights, are halogen and in fact are the kind in which are not intended to be touched and if they are touched, will blow up
edmontonsho
Edmonton Alberta
Considering I work in a household lighting store... as a rule halogen bulbs can not be touched. There are excpetions but they are not to common. I'll double check tommorrow with my boss to see what allows a halogen bulb to be touchable. You shoudn't have to touch it though, just wrap a piece of plastic aroud it.
edmontonsho
Edmonton Alberta
If you look carefully at a hologen bulb, you will notice either of the two following things.
1) glass bulb and filament inside (common for most hologen bulbs, ex the long and skinney 78mm's)
2) a small glass bulb and filament inside, all in a larger bulb. (not so common, but most twist in hologens will have that, ex JDE, GU10, and mr16 style bulbs.
Obviously the halogens within a bulb, can be touched.
