fog light ground connection
SHONJ622
New Jersey
I have a 91' SHO Plus and the passenger side fog light is being held up by a small ground plate and the screw to that plate is stripped. any idea how to get that stripped screw out with limited room. Also connection might be bad, not sure. Replaced that bulb by putting it in and both ones worked for a sec. Tapped bumper to test connection and they both went out. Replaced seperate fuse under dash and it was bad. The one that always works still works, but the one with the stripped screw still does not. any suggestions?
<small>[ March 27, 2003, 12:10 PM: Message edited by: SHONJ622 ]</small>
89 black SHO mtx
bean station tn
small needle nose vise grips to get the stripped screw out. it sounds like the one with the stripped screw is just loose mine does that eevry once in awhile. i have to crawl under and tighten it up again
