Fog Light Bulbs
91 SHOplus
Sholess 4 Now
North Jersey
OK, I did a search and the results were contradictory. I read that the bulbs are different from Gen1 to Gen2. I have a 91+.
shrug What fog lamp bulb do I need? H3 or 893?
BlackOnBlackATX
Dutchess County, NY
i would think you need an H3 since its a gen1, my gen2 uses 893. take one out and look at it though, it should say right on there. the 893 is a long kind of bulb. H3's are kind of stubby but either way take it to an autostore and they should be able to tell you which one it is. i also think the H3's dont use a socket type connector, they have a blade connector i think. the 893 is like a headlight, it has a socket type setup.
<small>[ January 09, 2003, 12:39 PM: Message edited by: BlackOnBlackATX ]</small>
91 SHOplus
Sholess 4 Now
North Jersey
Well, The Gen 1 takes an H3. Although my damn light still doesn't work, I have to go back a little further. Anybody know off hand what fuse to check?
<small>[ January 10, 2003, 11:37 AM: Message edited by: 91 SHOplus ]</small>
JaySHOguy
Bellingham,MA
Remove the dash panel under the steering column. Look under it, and you should see a separate fuse holder. THAT is the fuse for the foglights.
Pretty easy once you find it.
