ES_8CH_OH
White '94 ATX
I recently pulled my dash panel off to replace the tiny bulb that lights my headlight switch. I also pulled my instrument cluster out to replace my OD light. I put the dash panel back on to find that my fog lamps switch no longer lights. Everything else lights. The switch works, but it does not light. The green letters do not light, and the red horizontal bar does not light. I checked all the fuses and all fuses are good. I unplugged the harness and inspected the connections. Everything looked good. Put it together again. Still no lights. Where should I look to solve this problem? Headlight switch? Instrument cluster wire harnesses? Somewhere else?
-John
-John
