Fog bulb replacement on GenII?
91grnPlus
Roswell, GA
Any tricks or tips? Looks like I might need to remove the bracket to get to the bulb easier?
Thanks,
Mike
ohfosho
ontario SHOwner
ontario, canada
on the genII SHO's i could not be much easier...except if your car is lowered to the point that the front is scraping on every bump you go near.
just reach under, exactly where they are, twist the socket assembly (while squeezing?), and be gentle with the wires. when reinstalling, in it seems to be fighting-theres not enough wire, twist the assembly 180* and try again.
SlowHeavyObject
philly
Ditto on the wires. They are brittle from being under there. If your car is so low like mine, you can reach under the bumper from either fender near the tire, just gotta reach more. Another way to avoid messing up the wires is to disconnect the inline coupler further up the cables then take out the bulb socket and wires as one. You shouldn't need to remove the bracket unless you have aftermarket lights.
91grnPlus
Roswell, GA
Yep...just figured out today they are aftermarket lights. All rusted to all get out! I pulled both of them out and am looking for some good (not too much $$) ones to reinstall.
Mike
poffffd
