Eric VerValin
PiMPSKiLLET
Ok.. well I'm off to Ford to pick up a thermostat, then I need all my fluids. Is there any preferance as to coolant choices? I'm going to start this thing up with some max-life 5-30, my FL-1A, and don't know what kind of coolant to put in this baby.
Now I still need to get my front tension struts weged outta the car yet, and bleed out my brakes, but I want to fire this thing up now, and make sure I dont have any other issues. I was thinking about firing it up to let it warm up to operating temp, then drain the oil and change the filter. But I'm wondering what my luck will be with that, as I'm sure I'm going to have bubbles in the cooling system, and dont think it will be able to get up to operating temp before the heads get too warm.
From what I've read, you should be semi-kind to it on the first starting, let it warm up, change your fluids, then go beat the snot out of it. This sound right here fellas ? Thanks
