40BelowSummer
Yo. Well the time has come pull a motor for the first time and I want to do it right. Ive done two top end 60K's, rod bearings, and other typical misc SHO stuff. So this shouldnt be TOO hard
The car is sitting behind my house in a field, i have it on jack stands. I have already pulled the following items:
Radiator
Intake
IRCM
Coil Pack
Fuel rails
Airbox
Fan shroud
coolant overflow bottle
headlight assembly
most wiring
battery
power steering resevoir
etc
It is an 89' so from searching and reading, that should be one less thing to worry about. I have no engine hoist but my dad is bringing a forklift home tomorrow to either lift the engine/trans assembly out or lifting the body off the subframe.
My question is what things do I need to disconnect tongight to get it ready to drop the subframe? Im not as familiar with the suspension/drivetrain as I will be (havent learned that yet)
Motor Mount bolts, 4 subframe bolts, ???
Thanks
Radiator
Intake
IRCM
Coil Pack
Fuel rails
Airbox
Fan shroud
headlight assembly
most wiring
battery
etc
Thanks
