First time at the track.. Not very impressed
Corby
Porsche Eater
Huntervf, I've tried your technique, launching at 2k and I spin all the way till 5.5k but it's still accelerates pretty damn quick when I do this.... The tires spin but it seems like barely faster than the car is moving, every other way I've tried I either bog it like crazy or slip the clutch alot, your technique ive tried is by far the best, I think all I need to do before I go to the strip is air out the front tires a lil bit and I should be set. Thanks for the write-up!!
Huntervf
Bored now
Back in Michigan ... again.
A little bit of tire spin is a-ok, you'll never be able to get away from it. You just don't want to be smoking the tires is all.
Be sure to post up some timeslips when you run! :thumb:
Corby
Porsche Eater
Oh I will, hope to see a low 15 pass, if I get into the 14's I will probably be the happiest person in the world.
