First SHO
tauruswagonlove!
ontario canada
Just picked up a 99 SHO for 500 bucks starts runs and drives. needs rocker love,suspension, alternator. and the smaller things like fluid changes a battery and a good cleaning. dont know if the cams are welded yet, car has 235,000 km, and purs nicely
.WP 20150516 14 19 14 Raw WP 20150514 19 02 53 Raw 2 WP 20150514 19 02 13 Raw WP 20150516 14 44 53 Raw WP 20150514 19 02 04 Raw
Banshee
New York
Yes indeed. For anything sho related the knowledge base here is unbelievable
tauruswagonlove!
ontario canada
Are the cams welded to the sprockets?
Sorry, I had to say it.
""Just picked up a 99 SHO for 500 bucks starts runs and drives. needs rocker love,suspension, alternator. and the smaller things like fluid changes a battery and a good cleaning. dont know if the cams are welded yet, car has 235,000 km, and purs nicely"" so not yet i dont
tauruswagonlove!
ontario canada
haven't quite got that far yet just got it in the driveway this long weekend, off work tomorrow so i mite do some looking for a weld or a not weld we'll see.. anything else i should be on the lookout for?, it does run and sounds fine to me but hey my first SHO so im learning.
tauruswagonlove!
ontario canada
WP 20150523 10 50 00 Raw WP 20150523 10 53 23 Raw WP 20150523 10 49 52 Raw sadly i see no welds on the front, so most likely not on the back either. how should i proceed? car is parked in driveway no plates, got a few to many things off to start it rite now aswell.
GEN 3 SHO FAN
Canada
Hi, last year I was in the same situation and it's cost me around 175$ (can.) with towing.
If you're a little good in mechanic retrieve the intake (the surge tank) and slack the covers valve, call the best (and honest) garage you know (not Ford) and ask them if they are welding with a MIG (because of less particles process). Tow the car there they will just have to retrieve the covers and weld them (4). The rear are more difficult (less place) be sure to weld them at many place on cam to do this, you will have to "start" the car with all the coils unpluged. (I forgot 4 and the car want to run...:S ). This will give you access to the other side of the cams to weld them. After that, take the car at home and re-bolt the intake.
Before beginning, make a search here and on V8sho.com site to find photos of good welded cams.
Good luck,
shobroooo
