firewall passenger side/ coolant leaking
kevingotashotoo
200 or so ponies
peterborough,ON canada
just wondering if anyone if fimiliar with the coolant hoses on the passenger side coming out of the firewall...just above one of the catilitic coverters....either a hose slipped off or a plug fell out...but i think its got something to do with my climate control...i will get pics soon
TYSHO
Earth
Your heater core is leaking in the a/c box that dumps it out under the ecc connector on the firewall. I had the same thing happen! :frown:
kevingotashotoo
200 or so ponies
what should i do?, can i just bypass the whole heater core by taking the two hardlines that go to my firewall from my engine and put them together?
TYSHO
Earth
That's what I ended up doing! :biggrin:
TYSHO
Earth
Yeah, you can do it. Remove the two hoses and buy a new hose to connect the two coming from the motor. Ones bigger than the other, can't remember the sizes, and the hose I had around was the smaller one. If I could go back, I'd just buy the one for the bigger one and clamp the smaller one down real tight. It was a PITA to get the small hose on the larger pipe AND push it down some more! Or, an easier way, you can go find a barb reducer deal and run it like that with all proper size hose.
