shadow102
Ok i just did the valve shim adjustment/check i have checked all the gaskets they have all seated correctly and nothing got rolled over. however when i start the car i start getting smoke from the back exauhst manifold after it has been started for around 1 minute. i think it might be the wd40 i got back there when i was cleaning but i have started it up 4 times for periods of 5 min each and it smokes everytime. also i checked all the valves and made sure they were withing the clearence however i am getting a tapping koming from the front valve cover...did something seat wrong and should i take it back apart to correct it or is some of this a bit normal...also if it helps any i had alot of oil in my plug wells that went into the cylander when i took the plugs out i tried vaccuming it all out but would this cause any problems
