Ferendon
I noticed on SHOnut, it's mentioned that the fibertuffs can eat a steel or billet flywheel... How bad, and what are the chances of that actually happening? And with I be better off with a different clutch?
GR8SHO said:I have the total clutch package from SHONut in my 92. HD PP, Ceramic TOB and 9-puck disc. Still have the OEM style flywheel. If you study the design characteristics of all the components you will appreciate it far more than the stock clutch. But it doesn't drive exactly like to stocker and some people might object to that. I have a slight vibration at idle that I'm now used to. This new clutch is more grabby and easier to launch than the OEM. Absolutely no slip and easily spins my 235 Nittos. Car has a 3.2L upgrade. Good luck.
GR8SHO said:I have Alum SFBs. The rear motor mount is basically fixed for all intents and purposes having been shortcircuited by using a nut/bolt combo through the metal casing. I suppose those are contributors since there is less isolation from the drivetrain to the cabin, but my stock clutch didn't have that feeling.
Anyway it's no big deal at this point, and I'm enjoying the "new" clutch.
